View Full Version : kmbh c452 print yellow background on every printout p-22 error code appear
kizi57
11-12-2014, 05:19 PM
Please help as per subject
in every printout i there is yellow solid background (see attachment below).
also there is error code p-22
Thanking you in advance
27085
copier tech
11-12-2014, 07:41 PM
What is your yellow IU life?
kizi57
11-13-2014, 07:06 AM
Life of yellow IU is almost 70%
copier tech
11-13-2014, 09:25 AM
Start by cleaning the IDC sendors, run a gradation ajust, if still yellow background replace the yellow IU
cbp.patel
11-13-2014, 01:19 PM
drum charge unit problem. clean charge unit.
kizi57
11-13-2014, 01:27 PM
Thank you sir for your input, please let me know how i can find charge unit, do you mean laser?
B0265
11-13-2014, 03:08 PM
It might be the laser unit, we had a similar problem on a C451 recently.
WATTY
11-18-2014, 07:02 PM
Hello
I have had this on a c451 and it turned out to be the laser unit, covered it yellow on the entire page.
good luck
copyplus
11-20-2014, 10:54 PM
Is it possible to interchange the IU from C451 to C452?
minimerlin
11-21-2014, 08:23 PM
I would go for the laser. I have had the same problem but with cyan background! Place a bit of paper over a part of the yellow laser window. If a white stripe shows on copies/prints then that confirms it as the laser. :cool:
copyplus
11-22-2014, 12:13 AM
I am looking at buy a C452 which has a yellow background printing problem. The machine has only 56k copies on it. The owner demanding $600 for it. Is it worth buying that machine if 1) the laser unit is not working or the IU needs replacement. thanks
Smyers
11-25-2014, 12:35 PM
27085
Yellow IU may not be seated securely or its bad
Jamesb123321
11-19-2021, 05:12 PM
ive had this before, i would change the yellow drum first if that fails look at HV board
copier tech
11-20-2021, 06:56 PM
This was a post from the year 2014. I will assume the original poster has resolved the issue by now.
Synaux
11-23-2021, 07:28 AM
Well... you never know :rolleyes:
