View Full Version : BIZHUB C353 transfer belt wear
visaliagraph
11-13-2014, 12:40 AM
I've had an on going issue with my transfer belts getting worn on one side in my c353 Bizhub. The wear is about 2 inches from the edge of the belt towards the center and is always on the same side. It almost looks like heat damage, a sort of scuffed material that isn't shiny anymore and it causes the toner to lighten on the prints. Any ideas what could cause this? I have three of these printers this is the only one that has this reoccuring problem. Thanks in advance!
blackcat4866
11-13-2014, 12:47 AM
Check for matching scuff marks on the image units, and anywhere else in the cavity surrounding the belt. The last time I saw something like this there was a chunk of broken plastic wedged behind the 2nd transfer roller. It had carved out a wedge of the 2nd transfer roller, and occasionally surfaced long enough to score up the primary belt. =^..^=
visaliagraph
11-13-2014, 01:04 AM
Another strange fact is only the prints from the LCT show the lighter toner fade. The trays are fine. Weird to me.
blackcat4866
11-13-2014, 01:40 AM
Maybe moist paper patterns? Does it change duplex? What media type? Is it set to the proper media type? =^..^=
JR2ALTA
11-13-2014, 02:51 AM
wear on the edges is pretty normal. transfer belts are tricky devils, Konica 552s can look like the've been through a trash compactor and still produce great copies.
maybe you should print out some gradation charts to see which color and what clues stand out.
habik
11-13-2014, 03:15 PM
Check for flipped LED eraser cover upwards. Had it once.
Sent from my iDon't believe in marketing device using Tapatalk
