View Full Version : konica c250 c-3461 code
have a konica c250 that needed a fuser and a imaging unit. i was able to get a 100 ma fuse and replaced on fuser. the fuser message went away and just had replace imaging unit. put new chip on unit and then i got the c3461 code. i dont have a service manual so not sure if this is a fuser or a imaging unit problem. any help would be appreciated. although replace fuser went off i can see when i open and close front door that it says replace fuser soon. it should still work even with this message.
darry1322
11-20-2014, 08:32 PM
New Fusing Unit New Article
Release •
A new installation is not detected when a new
Fusing Unit is installed.
1. Check the Fusing Unit for correct installa-
tion (whether it is secured in position). — —
2. Check the Fusing Unit, PWB-M for proper
connection and correct or change as nec-
essary. — —
3. Reinstall Fusing Unit — —
4. Change Fusing Unit — —
5. Change PWB-M
Blizzoo
11-21-2014, 05:22 PM
Put a 1/16F pico fuse or 63mA wire type,not from glass...100mA is to high.
