JSC
11-28-2014, 08:10 PM
Hi..
We are getting a J-7330 (ZU-608 jam) on the only bizhub 951 we have in the field, which has only about 150K on it.
The machine will throw the code when 1st switched on:- There will be no paper in the ZU-608 or anywhere else in the machine.
After opening and shuting the doors the machine will work for about 10(ish) prints and then the code will fire back up, again this will be a phantom jam. After checking the sensors & machine the code resets for upto 10 prints and the code comes back.
We have stripped down the ZU-608, Pk Unit, and machine exit assy, swaped around the relavent sensors (PS601,603,604,605,609), checked input out put modes for the sensors, updated machine and accessories firmware, and spent hours trawling through CSES with no joy. We have the service and part manuals, and are Konica Minolta dealers.
We have ordered the Paper Detecting Board A04FH02000 and it has all the hall marks of a sensor problem and also as we can't think of anything else. it should be with us by Tuesday.
So im asking if any of you that have experience on this model I would be grateful for any input and ideas you might have, as with only one in the field our experience with this particular model is limited.
Cheers...
Cheers...
