View Full Version : BH-C-253, C-3723
Hansoon
11-30-2014, 08:46 AM
BH-C-253 showing occasionally service code C-3723. After reset it works for a few days and than codes out again. What do you guys suggest to do first, replacing the fuser unit or replacing the Printer Control Board and/or the DC-Power Unit?
Any hints based on your experience please?
Hans
paulrid
11-30-2014, 10:07 AM
have a look in service mode state confirmation, level history1 and see how hot the fuser is running at, from memory it's around 170 but I think it's best to check on another machine first. I'll check when I'm with one. You can adjust the temp in service mode, machine, fusing temp. Have a look there and see if it's been change. One last thing which I don't think it will be as it works for a while is take the fuser out and have a look if there's anything in there which is getting hot, like I say I dont think it will be that.
Is the machine in a hot environment?
paul.
laitang
11-30-2014, 10:32 AM
C3723: Fusing abnormally high temperature detection
1 Check the fusing unit for correct installation (whether it is secured in position).
2 Check the open/close operation of the upper right door.
3 Check the fusing unit, PRCB and DCPU for proper connection and correct or change as necessary.
4 Change fusing unit
5 Change PRCB
6 Change DCPU
allan
12-01-2014, 07:14 AM
Could be you customers power?
Hansoon
12-01-2014, 08:46 AM
Thanks Allen, but here in Germany we have an extreme stable power grid. In the past decades I had no single power related issue.
Hans
habik
12-01-2014, 03:40 PM
How old (clicks) is the fuser?
Sent from my iDon't believe in marketing device using Tapatalk
Hansoon
12-01-2014, 04:13 PM
150.000 K, Habik.
Hans
habik
12-01-2014, 05:04 PM
Hmm check the fuser connector wire harness (blue) fuser into coupling ( yellow) pwb had it once being split. From the machine side of the coupling.
Have you got any 2nd hand fusers to try? It might be simply the fuser it self.
avecosat
12-03-2014, 05:54 PM
I had the same problem twice and it was the DCPU .
Hansoon
12-03-2014, 07:16 PM
I replaced the fusing unit with the one from my own office machine. Have one DCPU ready in my car now. Thanks guys.
Hans
