View Full Version : C6000 Fuser ghosting
KM1Amsterdam
11-30-2014, 10:33 AM
So after 50k pages, fuser unit starts to ghost copy on paper. Replacing the fuser belt helps, but after 50k the same problem returns. Customer had 2 fuser units, both the same, after 50k fuser belt needs to be replaced.
One fuser has been refurbished completly, new rollers, bearings, still same problem after 50k.
blackcat4866
11-30-2014, 11:44 AM
Glossy media? Especially inkjet paper? =^..^=
KM1Amsterdam
11-30-2014, 01:40 PM
Not really just uncoated heavy stock
blackcat4866
11-30-2014, 02:05 PM
And heavy paper settings? =^..^=
KM1Amsterdam
11-30-2014, 04:14 PM
Sure + speed down & cpm down ofcoursem tried high and low temp settings also.
blackcat4866
11-30-2014, 05:04 PM
OEM toner and developer? =^..^=
allan
12-01-2014, 06:37 AM
Expensive exercise! Is TCR levels ok? Any specific color or all colors the same?
methogod
12-01-2014, 09:44 AM
TURN OFF SPEED DOWN, should not be an option.
If stock is very heavy there should not be an option
Speed down is to slow down paper running faster then it can move, very light stock, fine paper.
CPM - is FINE if you need it... its cycles per minute, that slows the cycles so its only feeds 1 sheets though before it starts the next, good when sheets are crashing.
what is specs of paper?
did you try another brand of the same paper?
what size is paper?
can you post image?
when you changed everything, did you replace the gear that control the pressure down control...
thanks,
