View Full Version : C-0204 error on C350
ismail
12-09-2014, 10:34 AM
I had this error 2 weeks ago but it turned ok. now i have the same error again and it is not fixing and i can't do nothing. I look at second tray and first tray and there is no paper jam. i looked carefully inside the right door and there is no paper or anything jammed there also. Where i must i look? Any suggestion?
laitang
12-09-2014, 11:02 AM
C0204 Detail:
Yellow PC Drum Charge Corona malfunction
Relevant Electrical Parts:
- Imaging Unit /Y
- High Voltage Unit/1 (HV1)
- Control Board (PWB-MC
Procedures:
1/ Check the Imaging Unit contact and correct or clean as necessary.
2/ Check the HV1 contact and correct or clean as necessary.
3/ Change Imaging Unit.
4/ Change HV1.
5/ Change PWB-MC
EarthKmTech
12-09-2014, 11:19 AM
its almost always a bent needle on the charge electrode stabbing into the cleaner. I have had long hair end up in there before too. (not mine)
ismail
12-09-2014, 11:32 AM
can you navigate me, where is that?
EarthKmTech
12-09-2014, 11:45 AM
inside the relevant imaging unit.
in this case - yellow.
ismail
12-09-2014, 12:27 PM
thanks for your suggestion. i took out the yellow IU, open it and clean it but not fixed. any other suggestion?
ismail
12-11-2014, 11:55 AM
Fixed. i don't know how, but it is ok. i pull out the yellow IU several times, and it get fixed when i pulled the waste box out and in. i dont know if there is something about that two, but after is ok . Now i have the C-0F3A. And as i see, it is worse. any solution for that?
