View Full Version : Develop Ineo +353 Drums & Toners
soichiro
12-12-2014, 01:16 PM
Hi all
I have the Develop Ineo +353 and doesn't recognize all drums and all toners. It stared when I tried to replace the cyan drum and load new cyan toner. All the part are original Develop.
2738727388
I closed the power; I pulled out toners & drums and installed again but no luck.
EarthKmTech
12-12-2014, 01:25 PM
I personally would be suspicious of a blown icp on the printer control board.
also make sure none of the chip contacts are mangled.
allan
12-12-2014, 01:43 PM
System 1->Initialization ->error clear if no luck then data clear. did both at the same time and that work. please let me know.
soichiro
12-12-2014, 01:46 PM
All contacts seems OK. The machine warned me about the drum that I need to replace it a 3 weeks ago. When toner became empty I replaced both. The loading procedure started but never completed. I opened the door pooled out the drum & toner (booth Cyan) installed again and then started not recognized all the drums and toners.
soichiro
12-12-2014, 01:49 PM
Could you be more specific please. How I go there?
allan
12-12-2014, 01:52 PM
Are you a tech? do you know how to access techrep mode? utility -> counter -> details -> "stop 0 0 stop 0 1" -> system 1 -> initialization ->error clear then data clear.
soichiro
12-12-2014, 02:25 PM
I'm not a copymachine tech. I'm the owner and the technicians are far far away.
I've all the above steps but I get the same message.
allan
12-17-2014, 06:49 AM
Any luck?
soichiro
12-17-2014, 10:57 AM
I've made all the steps (reset). I noticed that when I made the resets (error clear then data clear same time) and open the main door to switch it off for one moment pop up again the same error.
I've spoke to a lot of people but no luck at all. Everyone said that the main board if off (or something like that).
I don't know what else to do...
allan
12-17-2014, 11:07 AM
You have to swop boards next. ouch
paulrid
12-17-2014, 11:31 AM
Hello,
try a different cyan toner, I has seen this many times with non oem and its a corupt chip. If you still have the old parts put them back in and see if this error goes away.
paul.
