View Full Version : Konica Minolta C203 - Status Notification Settings
Jorvikps
12-12-2014, 03:19 PM
Hi all,
Another questions, this time related to the Status Notification.
We have all out customers setup so that it emails the companies dedicated operator whenever there is an issue with the machine i.e. Empty Paper, Low Toner etc.
We have never had a problem, and 90% of customers only have one machine per site and the others just identify via ip address. However we have had a request from one customer that we set the "Installed Place" name. We are however unable to find where this is inputted. We filled in the Machine Location in Machine Settings, this has however not copied across. The meter Count one give you a box, to name the machine.
See below for an example:
Occurred Time :01/12/2014 12:12:04
Installed Place :
IP Address :192.168.*.*
Error :
Thanks in advance should anyone know the answer to this.
Andy
Worqy
12-18-2014, 05:10 PM
Hey.
You can find the installation location in:
"Network" > "IPP Settings" and the "Printer Location" field.
Since you are using the same system we are, I have a question for you.
When you get a "toner empty" message, is there a way to find out what toner its for?
Now the operator needs to go to the machine and check which toner is empty.
