Hi, I started a new job recently and was given the task of hooking a C300 up to be used as a network printer. There is no setting anywhere in admin settings to set an ip address. It appears the ic-406 is dead as no fans are turning and no network led's lit on the lan port. If I disconnect the ic-406 and plug the network cable into the port on the box above the ic-406 those led's are lit so I know the network is ok, but even then no setting to set the ip address shows in the admin settings.
Are there any fuses inside the ic-406 I can check? There is what looks like a breaker push button but nothing happens when I press it. Any common failure points I can look at?
Have been an electro-mechanical field tech for 30 yrs, did a few years as a copier tech (Sharp, Panasonic) in the early 2000's, but have very little experience with Fiery controllers.
Thanks for any help.
Sam
CTM Group
Sam
CTM Group
