View Full Version : Bizhub - dry lubricant?
Hi guys
Thought id start another thread.
Need advice on the right dry lubricant to silence a C552 fuser / exit gear rollers..
Service/repair manual suggest drysurf. yet can't seem to find it anywhere.
As suggested in another thread. Ive set the printer to:
low power mode 15 minutes
sleep mode 90 minutes
return to low power mode "immediately" NOT "normal"
Just need to find the right lubricant without buying something wrong.. like WD40 which will eat plastic
So any advice?
or will the following be ok to use...
DuPont™ Teflon® Non-Stick Dry-Film Lubricant
WD-40 Specialist High Performance PTFE Lubricant Aerosol
WD-40 Anti Friction Dry PTFE Lubricant
Finish Line Dry Bike Bicycle Cycle Teflon Chain Lube
Dupont best? as its rated to 250c?
CompyTech
12-15-2014, 06:12 PM
Hi guys
So any advice?
I had a little bottle of that Drysurf stuff that came with a mod a couple years ago. Once I found it didn't really fix it, I threw it in the trash can..
You can try high temp grease of some kind, might work for a while. I was told NOT to grease gears because debris collects in the teeth and chews them up.
I would just replace the fuser. You can file a warranty claim on KMBS site.
minimerlin
12-15-2014, 08:31 PM
I just use fuser silicone oil..applied with the tip of a watchmakers screwdriver, does the job just as well.
This is a refurb printer. so i guess warranty is n/a
as for fuser, i think its newish
the noise is mostly coming from the exit rollers.
and there is a noise from the fuser, when it moves up and down. sounds like a dying cow lol
as for collecting debris. i guess a dry telon lub would be best? but was just after some advice first. last thing i want is the lub to eat away at any plastic
also someone recommended
Molykote HP-500
Molykote(R) Lubricants for Office Equipment Applications - Dow Corning (http://www.dowcorning.com/content/imaging/lubes_office.asp)
but can't find it anywhere
habik
12-16-2014, 03:16 PM
I have had success with Super Lube® High Temperature, Extreme Pressure Grease from Synco order nr 70006 - 6 cc High Temp. syringe. but since you asking DRY stuff..do not have experience. But if that fails :)
Try this :)
Please treat the following link as a joke as I haven't tested it...yet :)
Nuclear Grade Grease (http://www.super-lube.com/nuclear-grade-grease-ezp-55.html)
habik
12-16-2014, 03:18 PM
Regards the dying cow, could you record it and bang it on youtube. I really wanna hear it. The pressure welding noise is I'd say normal.
Try this :)
lol at nuclear grade. although it is rated to 235c
well i could try any lub. i just thought it needed to be dry lub?. because its near fuser and wet stuff will prob attract dirt and go hard from heat.
think i'll source Super Lube® DRI-FILM lubricant or WD40 Dry PFTE one
emujo
12-16-2014, 04:21 PM
Open the right side door, on the top of this door is where some of the noise originates, remove 1 sensor and 1 screw, and the whole assy comes off. You have 2 screws that hold the driven rollers to the drive rollers, remove these, and pull the shaft out of the driven rollers. Clean/lubricate the shaft and inside of the white driven rollers. Also remove and clean/lubricate the 2 gears and shaft that drive the rollers. Re-assemble and test for the noise. If it's gone then great. If not then you may want to invest in having a tech come out and pull the fuser drive and eject assemblies as these are a little harder to get back together correctly. Emujo
PeterG
12-17-2014, 04:56 AM
The only way you will silence a c552 fuser is with a rather large bucket of epoxy.:D
If it moves it will squeak.:cool:
Zeldaman
12-17-2014, 07:43 AM
Hi there!
Sorry to say it, but there is really no way to silence the fuser xmt installing a new one. We´ve tried all Minolta- bulletin-tips, used this dry lubricant (crap!), other special oils & grease. It only help for some days, then it´s as loud as before. Thinking about the time my colleagues & me had wasted makes me shiver. Often the new fuser makes noise after 2-3 month, then we send it back for warranty.
Greetings...
habik
12-17-2014, 08:29 AM
Can you record the area of fuser it comes from?
Is it for sure fuser? How about ITB drive?i
Is it a fast interrupted sound as if a mouse is having a wank or semi-continuous fat cat trapped in cat flap?
Sent from my iDon't believe in marketing device using Tapatalk
Thats got to be the funniest thing ive heard! and sounds about right. i will get a video and upload
Synthohol
04-06-2016, 03:02 PM
one of my favorite bulletins, actually has sound samples to identify where the noise is coming from.
enjoy.
blackcat4866
04-06-2016, 11:54 PM
Molykote HP-500
UKOG-0235FCZZ
http://www.partsimple.com/ukog-0235fczz-004-n-4.html
But I have to agree that it is not a long term solution to the noise. Your best chance of success is to install a new fuser and reduce the fusing temperature 5C or 10C. Also decrease your energy saver timer to as short as the customer will tolerate (preferably 5minutes or less).
It will still come back, but take longer. =^..^=
habik
04-07-2016, 12:48 AM
This is quite good and easy applicator. Had success on few occasions.
Amazon.com: Super Lube 51010 Oil Super Lube: Industrial & Scientific (http://www.amazon.com/Super-Lube-51010-Oil/dp/B015ZKT0X2/ref=sr_1_13/175-2150670-1253420?ie=UTF8&qid=1459985696&sr=8-13&keywords=super+lube+synthetic+grease)
dc313zd
04-07-2016, 04:57 PM
Krytox® Lubricants, Miller-Stephenson Chemical Co., Inc. (http://www.miller-stephenson.com/miller/krytox.html)
minimerlin
04-07-2016, 06:35 PM
I just use fuser oil from the old CF900 series machines. Applied with a drop on a mini screwdriver onto bushes etc, proves to be very effective for me.;)
habik
04-07-2016, 08:15 PM
Impressed! Very nice spec. 800 'F
Sent from my GT-I9300 using Tapatalk
dc313zd
04-07-2016, 09:19 PM
Indeed! this is DuPont's answer to Ricoh's (actually not made by Ricoh) Barrierta L55/2 grease.
dc313zd
04-07-2016, 09:40 PM
I use this in fuser's, I call it 'stay put', read the second link and scroll down to the pics where they baked it.
Krytox XHT-AC Grease, 2 oz. tube (http://store.tmcindustries.com/product.asp?itemid=48&gclid=COba3v6u_csCFVdahgodY9QKvA)
http://store.tmcindustries.com/assets/images/PDF%20Files/Chemours%20Krytox%20-%20XHT%20Overview%20Brochure.pdf
