View Full Version : Error Code konica 550 c 3102
hello i have changed the fusing unit i reset the machine and still the code c3102 is on.please help
allan
12-29-2014, 06:16 PM
does the fusser heat up. any heat? power supply would be next.
no it does not heat up.
padedwalls
12-29-2014, 06:37 PM
Trouble reset done????
13.1 Trouble resetting
13.2 Contents to be cleared by reset function
: Will be cleared (initialized)
-: Will not be cleared
Functions • If the all troubles occur and the status would not be cleared by turning main power
switch OFF and ON again, or opening and closing the front door, clear the status of
the machine.
Use • To be used when the status would not be cleared by turning main power switch OFF
and ON again, or opening and closing the front door in case of a trouble.
Setting/
Procedure
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
padedwalls
12-29-2014, 06:42 PM
Pretty certain fuser error must be cleared for restart through "Trouble Reset"... good luck
C3102 Fusing roller failure to turn • When the IH power supply is turned ON,
pulse signals are not input either of the
heating roller rotation sensor/1 or the heating
roller rotation sensor/2 within a predetermined
period of time.
⎯ A
It is a hard down after fuser error! Did your old fuser shred? (fall apart? Bind motors?)
the machine.
Setting/
Procedure
i have done everything you say for the reset but it does not solve the problem..
padedwalls
12-29-2014, 06:50 PM
What was condition of old fuser? Failure cause?
http://smarka.com/members/boards/content/CTmessages/61255.htm
what i'm getting at is that it may be a drive issue...
padedwalls
12-29-2014, 06:53 PM
http://www.copytechnet.com/forums/konica-minolta/9792-bizhub-500-c-3201-a.html
perhaps of more use! :cool:
Quick question????
You use old web unit to new fuser? Been awhile since i touched this model, but i think web unit is independent unit from fuser from parts.... i suspect your web unit may be the "binder". I preferred to replace with new when doing a fuser unit!
press roller of the old fuser was broken on the one side..
padedwalls
12-29-2014, 07:03 PM
sorry about above ^^^ I'm thinking of earlier models with a wet fuser :(
ok thank you
padedwalls
12-29-2014, 07:21 PM
Right door switch operation ok?
how ironic a branch email just came out from a senior tech about KC454 with C3201... he's looking for answers too!
"keeps coming back"
says his fuser is not binding & next is drive motor then PRCB....
good luck!
Service manual shows point to point connction checks when lamps don't come on pg 738 of 1501 pg pdf
padedwalls
12-29-2014, 08:00 PM
There's a motor M17 in rear machine far right of main drive unit same part # as fuser drive motor... can swap for troubleshooting (if motor error moves to main drive error, then its motor).... also check to see if all vertical & registration roller(s) moving freely. New 4/5/6/7 series have bushing tie ups causing fuser/transport drive seizure! Not sure if these older fuser motors drive vertical!
allan
12-29-2014, 08:29 PM
The Fuser gets regulated by power supply. Got this alot on B250 machines changing power supply fixed the issue.
EarthKmTech
12-30-2014, 12:35 PM
regarding 4 series with this code randomly appearing and not due to paper jams, its the fuser drive motor, we have had it several times.
regarding what i presume is a bizhub C550, if the error has been reset and keeps coming at random with a new fuser it wil be the rotation detection sensor housing and photo sensors. replace them all. I've had this before and pulled plenty of hair out because of this.
