wseyller
12-30-2014, 01:18 AM
Has about 13k on it installed in Oct.
The copier sounds normal during boot up but there is no life from the control panel except if you press the sub power button it will beep so it is getting some power.
Reseat connector on control panel and MFP board no help.
I can ping the device. So I try a test print from printer properties and I see the job in the drivers queue and then it disappears but nothing happens at the copier.
At one point I was on Pagescope web connection to look at count and ROM version and it stopped working giving page could not be displayed. I didn't think to ping but instead just rebooted and once it came back up it was fine again. Try another test print but the same as before.
Controller version is newest and engine is 1400 but newest is 1700.
I decided to download and try to install controller and engine firmware blindly by using the Direct Print feature in the Web Connection as will accept the PRN files for firmware upgrades. Progress bar showed it loading on the web browser and each time the copier rebooted. Not sure if any firmware updated or not but the engine version stayed the same.
I disconnected the HDD and powered on but no help.
Copier does not have any external memory modules.
Normally I would start with replacing the control panel but the other symptoms have me thinking MFP board.
