View Full Version : bizhub c220
vijaysharma
12-30-2014, 06:38 AM
hi,
when i'm trying to update the firmware of c220 the machine says invalid memory. Is anybody have solution :confused:
allan
12-30-2014, 06:41 AM
On start-up? Change the flash drive?
copier tech
12-30-2014, 11:10 AM
Format your USB stick, Fat 32 in Windows & only copy the .TAR file to the root
vijaysharma
12-30-2014, 12:22 PM
I format USB stick and copy the firmware in A0EDFW.tar file but it only showing invalid memory:confused::confused:
copier tech
12-30-2014, 02:52 PM
Try another USB as said above
vijaysharma
12-31-2014, 12:48 PM
I tried so many USB of different make but still not
copier tech
12-31-2014, 01:00 PM
Try & update the firmware over pagescope
copier addict
12-31-2014, 02:04 PM
The thumb drive should be between 2 and 8gb (although I have used larger ones). The file has to be on the root of the drive, not in a separate folder. I find it works best if there isn't anything else on the thumb drive besides the firmware.
Hope this helps.
mo0651
12-31-2014, 02:54 PM
Are you using the service port?
allan
12-31-2014, 04:18 PM
Mabe the problem is not with the USB but internal?
WildbillC
12-31-2014, 04:39 PM
Try unchecking "quick format"
vijaysharma
01-02-2015, 12:05 PM
hi, everyone
i'm using service port, and the USB 2.0 stick is between 1GB to 4GB of different make.
firmware copied in root drive of USB, but again machine showing invalid memory.:confused::confused::confused:
copier tech
01-02-2015, 12:16 PM
Have you tried updating the firmware via Pagescope?
vijaysharma
01-02-2015, 12:30 PM
I never tried to update the firmware via pagescope, can you provide me the procedure,,,,,thanks:(
SmellsHot
01-02-2015, 01:08 PM
TO see if the machine likes the USB stick just put it in the slot by the operation panel. I know you cant update the firmware this way, but the machine will either bring up the external memory screen or you will have a little red x through an icon on the display panel. If you have the red x than you need to find another stick...different manufacturer than what you've been trying. There really isn't any rhyme or reason to these things. I have best luck with corsair and Kingston....doesn't matter the size of them. I've had success with 2-128gb
