Hi everyone. I need some help with Bizhub C252 adjustments. When i copy something, the printer cutting the bottom part of the print (close to the edge). is there any way to force print closer to the edge? I tried printer area in service menu, but any change I do doesn't change anything. Any help will be appreciated.
Bizhub C252 - Printer area adjustment
Re: Bizhub C252 - Printer area adjustment
What happens when you do internal test prints? Is it the same from the platten glass and the ADF?Please do not PM me without asking first.Comment
Hey Pichulec,
I was having almost the same issue, printing or doing copy my print would be out like it was zoom. I found that the issue was our second tray which i did not noticed was selected as default because of the auto setting. Do a print test from the machine itself and then when you do a copy check what traay is the default for it...check it and make sure all the alignments are adjusted.Comment
