View Full Version : cant find this...
methogod
01-04-2015, 09:01 AM
not sure why but i cant find the
install book and parts book for the
FD-503
Install manual
Parts manual
I recently got a lot of used machines, in this lot was a almost brand new FD-503 just missing some brackets to install into my C6501 or C7000. I get alot of request for UV coated booklet covers on certain jobs. Want to try to coat and score then post feed though the cover feed on the FD-503..
really need the install book, so i can order the right brackets. Dont want to guess...
copier tech
01-04-2015, 11:48 AM
A quick google search & I found the install guide
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCgQFjAB&url=http%3A%2F%2Fwww.costarelli.it%2Fsupporto%2FDe velop%2FIneo%25206000%2FDEVELOP_ineo%2B6000%2B7000 %2520Options%2520Setup%2FPB-503_Setup.pdf&ei=XCapVMuJMZbxaK-WgPgJ&usg=AFQjCNHZXKve4whyD88tkFrF06w4CTRGnA
methogod
01-04-2015, 11:54 AM
yea found that is the PB-503 = perfect binder. different accessory.
Mick01
01-05-2015, 12:28 AM
Hi,
Send me a PM. I should be able to get these for you.
If it is just the brackets you want i can probably get the part numbers also.
