View Full Version : bizhub 20P laser counter reset
Specialist
01-06-2015, 05:34 PM
Can't find out how to reset the fuser or laser counter on a bizhub 20P. Anyone got ideas? Is it like replacing IU (hold Go button 4 secs)?
giddyupngo
09-01-2017, 08:21 PM
I also have this question, anyone?
Phil B.
09-01-2017, 08:27 PM
The reset isn't covered in the service manual? hmmmm Seems it should be!?
giddyupngo
09-05-2017, 04:31 PM
Here is the answer, there is a utility at KonicaMinolta.com under utilities in One-Stop product support. The utility works in conjunction with small files also available in the same area of the website. Part of the problem may be that this is a re-branded Brother machine.
Download BrUsbSN_KonicaMinolta.zip and Replace.zip, and follow these instructions.
37539
Phil B.
09-05-2017, 06:59 PM
37539
tell me the brother equiv machine ... most times you can get to brother reset by " at ready press 3& 9... go to reset menu and pick the item.
giddyupngo
09-06-2017, 02:20 PM
tell me the brother equiv machine ... most times you can get to brother reset by " at ready press 3& 9... go to reset menu and pick the item.I don't know the brother equivalent, just saw Brother Inc. in the files above. I meant it is different than the Konica Minolta way.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Phil B.
09-06-2017, 02:35 PM
I know they are a brother engine.. even the display info is the same as brother.. I can't remember the Brother model tho.
copyguy69
09-06-2017, 03:57 PM
It is an HL-5380 cross reference. The reset is done with the maintenance utility on your computer. good luck
copyguy69
Phil B.
09-06-2017, 04:09 PM
copyguy69
according to the Brother tech support page ... there is no HL 5380 machine
copyguy69
09-06-2017, 04:16 PM
Look under the service manual for the HL-5370 and you will see the 5380 listed. I don't know why it is not listed, but it is there. Good luck
copyguy69
