View Full Version : C35 Error 0094
earney
01-07-2015, 12:00 PM
I have a C35 that is now displaying error 0094. I had originally attended due to colour registration issues (no error code) so had cleaned the lasers and removed transfer belt checked all ok re-assembled and realised the right door was stiff to close. This was an issue that we had noticed before but a good shove got it closed. It is still hard to close but now displays the error 0094.
Following advice I found online I have removed the pad from the 2nd transfer solinoid and checked the springs on the door but still same issue. Im assuming its due to the door. Any advice?
Gift
01-07-2015, 12:25 PM
Yeah we've went that way, too and ended up swapping the right door assy to fix 0094
EarthKmTech
01-07-2015, 01:08 PM
make sure the idc sensor shutter is opening properly - it is a piece of crap and there is a bulletin on it.
If the idc shutter does not open the machine assumes the transfer roller pressure/retraction operation is not successful - this is how it tells the operation is completed as its the transfer roller that opens it.
Dont know about the stiff to close door, that is perhaps because the transfer roller has stopped in the pressed position.
earney
01-07-2015, 01:40 PM
Yeah the shutter opens OK manually by hand using the actuator on the right. However if the issue is with the door it may not be opening via the gear system on the door itself. It's hard to tell. I can hear the solenoid clicking away once the machine boots up then displays the error. I'll check later by marking the gear to see if it's actually turning once the door is closed
EarthKmTech
01-07-2015, 02:18 PM
C35 door replacement is a PITA, it is actually easier on the C25 oddly enough. Hope you dont need to change it ;)
mo0651
01-07-2015, 03:41 PM
You mentioned that you had removed the transfer belt.... Did you get the plastic guide back into position? It's the one you lower out of the way... it makes the door hard to close.
earney
01-07-2015, 04:32 PM
Not sure exactly what one you are talking about? Is it the guide that houses the IDC sensor?
earney
01-07-2015, 05:11 PM
http://tapatalk.imageshack.com/v2/15/01/07/41ea1339f40cc4036928ccf9d87e8f65.jpg
earney
01-07-2015, 05:12 PM
Thanks, got it sorted. Way back when there were image problems maybe 2 years ago the transfer belt was removed. The guide below that houses the IDC sensor was left in the lower position hence the door hard to close. Couldn't tell you how it has worked for two years but it's sorted now in the upper position the error has now disappeared and prints are perfect. Noob error [emoji20]
mo0651
01-07-2015, 05:51 PM
YEP!!! YOU GOT IT!!! Crazy little cover.:cool:
allan
01-07-2015, 06:19 PM
Had a broken transfere roller retraction gear cause this once machine can not open the sensor shuter. Q-bond works magic. the duplex units screws also break out.
EarthKmTech
01-08-2015, 02:39 AM
WTF, I didn't think you would be able to close the door like that at all.
allan
01-08-2015, 06:33 AM
Sorry not the screws the plastic hooks keeping it assembled
fin
09-18-2019, 10:58 AM
Hi guys, have had the same error code on the c35 twice in the last year, with the shaft breaking causing for the error code 0094 i know that if i was to replace the door the error code would be removed but this would only be a short term fix as the shaft will break again, i was wondering if anyone has an idea of what could be causing the shaft to break so regularly
