View Full Version : Dead Machine print stop
stedros
01-11-2015, 03:06 PM
Hello friends I have a machine bizhub c550 it is showing print stop when ever u try to send work on it how can I solve it because it is puzzling mi, thanks in advance
allan
01-11-2015, 11:07 PM
Do u need to put a code into the machine to access the functions?
copierwhisper
01-12-2015, 04:17 AM
I had a C353 that acted the same way because the image units had reached 150% of life. With the firmware and proper settings that allow the machine to run components past 100% is great, but in my case it caused the print stop situation...once I replaced the image units that were at 150% the machine ran great again. Good Luck!
allan
01-12-2015, 04:59 AM
The massage i was thinking of is "deleted due to error" not "print stop" sorry about that.
deepdiver
01-13-2015, 11:09 PM
Might be barking up the wrong tree here but I think you may have no stop firmware installed and 1 or more consumable items are way past life. However, you need to check the IU life stop setting in enhanced security mode and set it to no stop.
