View Full Version : PRO 1051 density stability
fajdoooo
01-13-2015, 11:10 PM
Hello . I have a problem on the copier pro1051 . When you print a book of 30 pages , is a problem that image once dark , sometimes pale . Not straight-line printing throughout the procedure . Has anyone had a similar problem?
I have seen this I would change dev run all set ups for dev change. then go into test chart pint outs and run 200 of test chart 12.
fajdoooo
01-16-2015, 10:20 PM
yes, but how too, I tried os SW27-5/6, but....
How to what test chart 12 is under outputs under test output in service mode
fajdoooo
01-18-2015, 12:11 PM
I tried 200 test charts, but it was not the same. I also tried to switch SW27 to 1 but it vas not ok.
Luther
01-18-2015, 05:03 PM
clean the sensors near the drum and install a new charge corona
fajdoooo
01-18-2015, 07:36 PM
I firs clean the sensor on the drum vith alcohol, and replace the corona, drum and developer, make all the setting vhen replace the drum, but it was the same s..t:(
