View Full Version : bizhub c352 memorizing setting
cristian
01-15-2015, 05:55 PM
How could i memorize the settings that i make in the function controll (setting the density and the background removal), at an Bizhub C352?
Thank you.
allan
01-15-2015, 06:47 PM
First change the functions the way you want and then.
Utility -> user settings -> copy settings -> current settings
cristian
01-15-2015, 07:07 PM
Sory but it didn t work.
Utility -> user settings, OK, but after that i have no copy settings, only the copier settings. And, in the initial settings i have allready marked - current setting . After the job done with the new settings, the settings ( marked with a point upon the cases....) come back as initial...
allan
01-15-2015, 08:48 PM
I do apologise for that it is not like the newer machines.
Got this from manual
Initial Setting• It will not be displayed when the following setting shows that authentication device or
vendor is mounted.
[Service Mode] → [Billing Setting] → [Management Function Choice]
8.5.4 Copier Setting
A. Auto Paper Select for Small Original
B. Auto Booklet ON when Fold & Staple
Functions • To register the default setting for the copy mode function, the scanner mode function,
and the fax mode function.
* The machine is initialized at the following timings:
• The main power switch is turned ON.
• Panel is reset.
• In an Interrupt mode.
• Auto Reset
• The password entry screen for account track is changed.
Use • To change the Initial mode setting to meet the user’s need.
Setting/
Procedure
<Current Setting>
• To register the copy mode, scanner mode, or fax mode set on the panel.
• Carry out this setting after the necessary setting for each mode.
<Factory Default>
• Mode set prior to the shipping.
• The corresponding setting will be the one which has been set prior to the shipping by
carrying out this setting from each mode screen.
This is just default mode
allan
01-15-2015, 09:14 PM
Registering copy programs (Mode Memory)
Up to 15 copy programs can be registered.
A name of up to 16 characters can be specified for the registered copy programs.
To store a copy program
1 Using the touch panel buttons and control panel keys, specify the copy
settings to be registered in the copy program.
? Can the current settings be checked?
% To check the currently specified copy settings, press the [Mode
Check] key.
2 Press the [Mode Memory] key.
The Recall Copy Program screen appears.
3 Touch [Program Registration].
Hope this helps
cristian
01-15-2015, 10:18 PM
[QUOTE=allan;453692]I do apologise for that it is not like the newer machines.
Should be easier than that...Basiclly what i want:the density and the background removal are show as a scale set usually in the middle and marked with a small point.What i want is to move the setting for those two scales a little bit to the right or to the left, those setting must be permanent, and the points must remain on my setting permanently. Untill now i move manually the values but after i finished the job, or after an reset, the value comes back to the middle.
allan
01-15-2015, 10:23 PM
Why do you need to do this?
cristian
01-16-2015, 04:07 PM
My copier is printing and copying a little bit dark and i want to set it to copy and print more lighter, without changing the settings for each job.The computer interface settings are not working as good as i want to..
allan
01-16-2015, 04:19 PM
Then the Image units could be shot.
Try Gradation adjustment before doing this.
Try this under service mode -> Image process adjustment
10.6.2 D Max Density
10.6.3 Background Voltage Margin
Functions • To adjust gradation, color, and image density to target reproduction levels by varying
the maximum amount of toner sticking to paper through auxiliary manual fine-adjustment
of gamma of each color after gradation adjust.
Use • An image quality problem is not corrected even after gradation adjust has been run.
Adjustment
Range
“0” (-10 to +10)
Adjustment
Instructions
To increase the maximum amount of toner sticking, increase the setting value.
To decrease the maximum amount of toner sticking, decrease the setting value.
Setting/
Procedure
1. Call the Service Mode to the screen.
2. Touch these keys in this order: [Imaging Process Adjustment] → [D Max Density].
3. Select [COPY] or [Printer].
4. Select the color to be adjusted.
5. Enter the new setting from the 10-key pad or [+/-].
6. Touch [END] to return to the [Process] menu screen.
7. Touch [Stabilizer].
8. Touch [Stabilizer Mode].
9. Press the Start key to validate the adjustment value.
10.Check the copy image for any image problem.
NOTE
• If the setting value has been changed, be sure to run an image stabilization
sequence to make valid the new value.
