I have c451 that will not reconize blk IU any help
blk IU
Tags: None
Re: blk IU
What is the error message ?
Where did you get the IU ? Did you get it locally or overseas ? -
Re: blk IU
There is no error code had tech come look he replaced 2 sensors this did not fix problem
he had no idea his sug was to replace terminal where IU plugs into machine
any one got any suggestionsComment
Re: blk IU
I have replaced power supply board and high voltage board still will not reconize blk image unit any one have other suggestions need helpComment
Re: blk IU
What this machine just shipped to you? It might of gotten twisted...causing the chip to not to align correctly.
Also, consider the Lock Plate mod (A00J P331 00) mod (or just put a PH cleaning pad from tray 1/2 between the latch and the IU)Comment
Re: blk IU
Put lock plate mod in also tried the cleaning pad in lock machine has been here over 1 year
Have not tried firmware yet thanks for info all help is greatly appreciatedComment
Re: blk IU
The contacts on the IU are not making an adequate connection (somethign bent, broke, et cetera).
A wiring harness has been damaged.
You need to replace a board--I would suspect HV1 board, but if the Cyan IU is working that means the HV1 board is half-working??
(I am going off memory here--it might be the HV2 board for K and Cyan...)Comment
