View Full Version : Bizhub c451 Problme with cayn. Spots
irakli3443
01-27-2015, 02:39 PM
How do I remove these spots?
And what is broken?
2777327774
emujo
01-27-2015, 03:53 PM
What are you copying? It looks like you have just closed the ADF and made a copy of the platen cover. Same junk on both sheets of paper. If this is the case then clean the white cover. Emujo
irakli3443
01-27-2015, 04:07 PM
it's from Ms Word print out
irakli3443
01-27-2015, 04:19 PM
somebody can help me how clean this spots
Synaux
01-27-2015, 04:27 PM
Have you tried replacing the Cyan Imaging Unit?
irakli3443
01-27-2015, 06:03 PM
it's new. only 1k metter.
how i clean it or clean from programe
allan
01-27-2015, 06:24 PM
Do a half tone at value "0" for cyan that would be interesting to see if it appears on there. Also what is your TCR% ? Could be a bad contact.
irakli3443
01-27-2015, 08:03 PM
i don't know haw make - half tone at value "0".
and where can i'll search TCR?
I'm new in this machine system. please write me how make that steps.
allan
01-27-2015, 08:17 PM
Go to service mode -> Test mode -> Halftone pattern -> use number keys to change value and select cyan load paper and press start . useful to IU condition.
Go to SM -> State confirmation -> Level History 1 (note if no print have been made TCR values would be 0) a good Toner to Carrier Ratio is 6.5% toner but from 4% to 8% is acceptable.
"0" is supposed to create no image and "255" max density.
irakli3443
01-28-2015, 06:35 AM
TCR-C = 6.40
27782
allan
01-28-2015, 06:40 AM
Do a half tone at "0"
irakli3443
01-28-2015, 07:40 AM
I did it. but when I scan. But after A scan, it will no longer be seen. there is little spots.
how can troubleshoot machine
