View Full Version : Konica c6500 Image problem
Love Konica
01-28-2015, 10:54 AM
Hi all,
Please help me, I have a problem, when I print a file there is a yellow line on direction feed paper as image below
27783
I have tested charging, belt, drum. I have changed the drum, charging nothing chage. I print test pattern 53 with 4 color set 0, but the yellow still apprears. When I test print on grayscale it disappears.
Thanks in advance.
Cookr
01-28-2015, 02:40 PM
Tried cleaning the charging corona? looks like could be that to me. maybe even the laser lens's
dljorg
01-28-2015, 02:53 PM
Hello -
Line does not appear when you print gray scale and that is a good diagnostic. So is running test 53 set to zero.
When you print gray scale the color drums are not used, only black. Also the transfer belt is common to both color and black printing so that can be eliminated.
You say that you changed the yellow drum and corona charger so those are eliminated.
At this point I assume you have cleaned the drum and dev unit area very thoroughly so there is no possibility of some thread or fiber touching the drum or developer brush. Something touching the yellow drum would discharge it in that area and cause the line.
Leaves us with two possibilities, Yellow dev unit, and the laser. To eliminate the dev unit, cover the toner entrance hole with tape and swap the dev unit into another color channel say magenta. Then run (just once) pattern 53 again set to all zero. If the line is still there and is yellow its the dev unit. If the line is now magenta its the laser.
Hope this helps.
Love Konica
01-29-2015, 04:54 AM
Hello -
Hope this helps.
Thank you, I have swaped Yellow and Cyan dev unit, now the reason is laser unit, what should I do next?
Again thank you very much.
Love Konica
01-29-2015, 09:24 AM
I have a good news and a bad news. The good news, I have swaped Y and C laser unit, then print 53 pattern, the yellow line still appears. So the laser unit is good. The bad news, I have not found the reason yet :D.
methogod
01-29-2015, 10:59 AM
Did you try to swapped drums?... see if the issue says with the drum or not.
i would also try to make a print with the yellow corona removed. see if the flood is even.
could be DV unit so you may need to swap that as well just test with door open so no toner is added.
i would also check power at the machuine make sure its a good power source.
then if all else firmware, then recall standard data.... see what happens.
pepper38_cnd
01-29-2015, 11:27 AM
Ok so you say you swapped the devs and the line changed to Magenta. Then swapped lasers and no change. Drums and Charge made no difference. Then I would think the only thing that stayed constant the whole time is the yellow transfer roller?, which of course is retracted when doing grey scale? Would not usually give a dark line but it's worth a try.
methogod
01-29-2015, 11:35 AM
he never swapped DV units...
Love Konica
01-29-2015, 12:39 PM
I have swapped Developer unit, drum unit, laser unit, Led, charging nothing change. When I swapped Led the yellow line became blur but still appears.
methogod
01-29-2015, 01:01 PM
what about belt and transfer roller, cleaning blade...
can you swap the entire transfer unit?
gig the door, run a test print, and stop it before it transfer to the paper and look at the transfer belt. see if its on the belt. or if it shows up because the belt is not being cleaned properly...
Love Konica
01-29-2015, 01:27 PM
I have changed transfer unit (under belt), changed belt but nothing changed. I will do as you said and report.
Thank you very much.
Love Konica
01-29-2015, 05:56 PM
Once again I have a good news and a bad news. The good news is after all changed the machine run well, the yellow line disappeared. The bad news is I don't know why :D. But I think it involves in Led.
Outlander
02-03-2015, 07:30 PM
I had similar problem on C7000 with Cyan line and cause was dirty Erase LED bar below Charging Corona Unit.
KM1Amsterdam
02-09-2015, 10:51 PM
I case it returns, try to clean the container, where you slide in the charging corona. Sometimes toner deposits cause short-circuit of corona. Vacuum, brush and wipe with alcolhol.
