View Full Version : Error Code C-2721 is coming in C8000
Saghir377
02-02-2015, 10:41 AM
Good afternoon hope you are all fine. I have one machine bizhub C8000 its showing C-2721. 1st time i saw this code machine is around 500km away just i want to know if some body encounter with this code or have some solution or can sagest some parts any kind of help.
thanks & regards
bigwul
02-02-2015, 11:25 AM
Re: C2721
Code happens when the separator assembly next to the second transfer roller has a short or arc.
Check for good connection at the red wire to the separator. Use a pliers to squeeze the white plug to get a firm contact.
Red Wire PN 65AA90250
Terminal connector at machine frame PN 65AAR74600
If the machine is run many times with code C-2721 it can destroy the HV2 transfer power supply.
laitang
02-02-2015, 12:05 PM
27833
