View Full Version : Minolta DI-450 Error C1330
Have a Minolta DI-450 with error code c-1330 on display. Does anyone any suggestions as to what is causing the problem.
Thank You
Jack
Raymondd
05-07-2008, 03:21 PM
Jack,
Did you open and close the front door and turn copier off/on?
chuckt528
05-07-2008, 03:25 PM
Reset, as Jack said. If problem comes back at least 3 times check/replace main or print control board
chuckt528
05-07-2008, 03:27 PM
If recurring, main or image process boards.
ni311
05-08-2008, 07:06 AM
C1330
VD signal error
A LOW VD signal is not detected even after the lapse
of 60 sec. after an IDREQ signal has been output.
Thank all for this info. I unpluged all the conection on the A Board then repluged them and it works great.
Thank You All Much
Jack
