View Full Version : PH UNIT K BIZHUB C353
backspace
02-15-2015, 09:50 AM
HI,
Has anyone tried PUT PH UNIT (ANY c or K...) BIZHUB C203 / 253 IN The BIZHUB C353?
tnx
EarthKmTech
02-15-2015, 11:14 AM
yes, you can and it works.
the difference is the polygon motor is not rated for the higher RPM.
it may work for a while or it may work forever, only time will tell. I have only done it temporarily with spare used ones till the correct new ones came into stock.
backspace
02-15-2015, 11:21 AM
Do I need and upgrade FW or not?
EarthKmTech
02-15-2015, 12:39 PM
No, fw will make no difference
allan
02-15-2015, 04:57 PM
Good info. The engine speed should be the same on the 2 machines the time between paper feeds would be different. "Marketing bulshit"
EarthKmTech
02-16-2015, 08:33 AM
paper movement speed is actually faster not just a lesser gap between pages.
I seem to recall the c353 also has more cooling fans than the slower versions too.
but in reality theres bugger all cost difference between manufacturing the slower machine compared to the faster one in the same engine type, it is just marketing bs.
I know for a fact some cunning individuals have converted c203/c253 to operate as a c353 too.
hotfuser
02-16-2015, 10:54 AM
HI,
tnx
You can put a C353 PH in a C203/253 but the other way round i cant seem to get it too work due to the polygon motor speed.
habik
02-17-2015, 09:13 AM
That last paragraph is brilliant.
Sent from my iDon't believe in marketing device using Tapatalk
Issac-brock
02-24-2015, 02:57 PM
Just a note on this thread. Be careful ordering boards. I ordered the MFP to troubleshoot what turned out to be a bad laser in a new set and accidentally ordered a 353 mfp for my 253. Machine boots to hourglass forever. Won't make that mistake again.
In the end it was a faulty laser causing a "warming up" message then intermittently a laser code.
D Colour
03-24-2015, 02:17 PM
Hi all
We have a C200 showing C4153 (Y Laser issue). Can we use the lasers from a C203/C253/C353 to replace this faulty one?
James
hotfuser
03-24-2015, 03:10 PM
Hi all
James
No they are unique
D Colour
03-24-2015, 03:16 PM
No they are unique
thanks! and bugger!
