View Full Version : Miscellaneous Ricoh MP 5002 Developer Change (Entering lot number)
Doug James
02-16-2015, 08:08 PM
I am changing the developer for a Ricoh MP 5002. I can't find the manuals which I really need (I miss Paul) Am having trouble entering the lot number to set the TD sensor in the developer set up. I have entered every number I can find and it still won't execute the set-up. Any help will be soo appreciated...
logrady2331
02-16-2015, 08:25 PM
You can put any number in there you want. The lot number is for Ricoh tech support when you call a problem in. You can just put the date in: example (021515) hit the # key, execute, yes, off you go. Be SURE to either take the toner hopper out or put a piece of paper between the drum unit outlet and developer unit inlet to block any toner from falling out of the hopper and over toning the new developer.
logrady2331
02-16-2015, 08:27 PM
PM me and I will do you a solid with the parts and service manual since you are a fellow Okie. I grew up in Lawton and worked in Stillwater before moving to Arizona.
slytukana
02-18-2015, 10:41 AM
Bizhub
slytukana
02-18-2015, 10:48 AM
Hi guys thanks for joining you.
I had a problem with bizhub 195 . It displays "bios mode" when I switch on the machine and I try installing the FW it says the device is not ready.
