allan
02-25-2015, 05:02 AM
Hi Guys
I have this one B601 that is giving me a bad background, i have seen this before but was not my problem to fix, that machine ended up scraped so im not sure how to fix this.
Did clear counters.
installed new drum, dev, blade. 600k on the clock
check dev bias connection to be 5 ohm which is good.
check grid voltage to match new drum.
contact springs is all good.
changed charge unit.
check all voltage setting with other machine to make sure it is in same range.
changed the dev unit.
Please look at the sample.
28192
:confused:
Help is very welcome!
Line on the one side is a bad UFR.
Did clear counters.
28192
:confused:
