View Full Version : BH Press 6000 Lines on trailing edge
MAD0RAM
02-26-2015, 10:33 PM
http://i299.photobucket.com/albums/mm292/mad0ram/IMG_3149_zpsbjkumsqn.jpeg (http://s299.photobucket.com/user/mad0ram/media/IMG_3149_zpsbjkumsqn.jpeg.html)
The lines are cross feed on trailing edge.
They are visible on the transfer belt but have never been able to see them on the drums.
http://i299.photobucket.com/albums/mm292/mad0ram/IMG_8933_zpsnbcpngf5.jpeg (http://s299.photobucket.com/user/mad0ram/media/IMG_8933_zpsnbcpngf5.jpeg.html)
MAD0RAM
02-27-2015, 10:42 AM
No thoughts?
Heading out this morning and will install fresh firmware I believe it is current but will reinstall.
This shows the lines on the transfer belt.
http://i299.photobucket.com/albums/mm292/mad0ram/IMG_1989_zpstrn0pkvz.jpg (http://s299.photobucket.com/user/mad0ram/media/IMG_1989_zpstrn0pkvz.jpg.html)
http://i299.photobucket.com/albums/mm292/mad0ram/IMG_1990_zpsvmy0pqa7.jpg (http://s299.photobucket.com/user/mad0ram/media/IMG_1990_zpsvmy0pqa7.jpg.html)
MAD0RAM
03-09-2015, 11:11 AM
Wow still no help?
No thoughts?
When the print process is complete, does the lines still appear on the belt unit and is it cleaned off by the cleaning blade?
MAD0RAM
03-10-2015, 01:23 AM
All lines are cleaned off and all internal test prints come out without the lines.
Tested file in shop and had no lines.
Going out again tomorrow morning.
Does it happen when you copy? Lighter stock? It looks electronic from controller. Check you cable connection to PC remove and reattach. Reboot PC. Swap out video cable to PC if you can with working one.
empiru
03-13-2015, 02:03 PM
I've seen the exact same thing about one year ago, on a Press C7000P, with IC-413 Fiery Controller. I know for sure it was a controller issue, but I don't remember exactly if the solution was reinstalling the system software on it, or just installing a patch that resolves this issue (I didn't do it myself, that's why I can't tell exactly).
Albonline
03-13-2015, 06:04 PM
cic card, cable, or fiery system code/patches . put only patches that your controller needs for your customers needs. have seen unneeded patches cause things like you have here.
