View Full Version : Lexmark XS796de doc feeder adjustment
nathicana
02-27-2015, 05:47 PM
I'm trying to correct a side to side image shift on a Lexmark XS796de. It only occurs when the original is fed through the document feeder. Does anyone know the df centering adjustment? Lead edge timing is fine but I would like to know all the adjustments. The problem happens on single sided and duplex. On 2:2 duplex the up facing side has the shift but the side facing down in the df comes out properly centered. On 1:2 duplex both sides are shifted.
Firmware has been updated. I looked in 26 and 36 mode and didn't find the adjustment. There must be an adjustment mode I don't know about or a calibration procedure.
subaro
02-27-2015, 11:10 PM
http://downloads.lexmark.com/webcontent/training/CX792/C792_X792_Study_Guide.pdf
brodstol
02-27-2015, 11:14 PM
Enter 2 and 6 Configuration mode
Go to Scanner Manual Registration
Print Quick Print test and then use that page to do the copy quick test
You will then need to make adjustments through the ADF FRONT menu.
Use horizontal adjust to get the image centerd.
Hope this helps
nathicana
03-02-2015, 04:56 PM
Hope this helps
Thank you this adjustment works.
redneckstylin
03-02-2015, 07:13 PM
manual on its way sir
