Synaux
03-01-2015, 12:31 AM
So, apparently some 110lbcover stock was mixed up in some 100lb Hammermill cover and it naturally jammed in the side hatch (below the bypass)
Changed pickup rollers (even ordered a few of the new roller mentioned in this thread (http://www.copytechnet.com/forums/konica-minolta/63313-c652-tray-3-jams-2.html) for the newer MFPs).
Everything was cleaned and recleaned, nothing is bent, broken or blocked as far as I can tell...it is not generating a single jam or warning code (perhaps the bulletin listed in the above thread may not be as relevant without those codes?).
I after a cleaning it will run 20lb out of tray 3, but it refuses to run cardstock (thick 3). Jams are inconsistent in location, but I never see it reach the vertical conveyance section.
Tray 4 will randomly jam on thick 3 paper now, but will run 20lb just fine.
All paper is running straight and not dinged, dented or chipped anywhere. The original piece that jammed had a few dings on the edge, but it was not torn (seems they actually listened to me this time and did not haphazardly yank the paper out).
I was thinking about those conveyance leveling section rollers, what do you guys think?
Total Meter is 666k (lol)
Tray 3 64k • Tray 4 111k They must have been reset by someone...
