View Full Version : bizhub c252 error c-f023?
charlibravo
05-09-2008, 11:33 AM
What this c-f023 error means?
What can i do to resolve this problem?
Thanx in advance
ni311
05-09-2008, 12:38 PM
CF023
MsgQue OverFlow
An exceptional instance occurred due to the unexpected Parameter in the System F/W.
Relevant Electrical Components, Units, and Options - MFP Control Board (PWB-MFP)
Try to reset it. If it is still showing up, you should try a new firmware version. If it is not working with a new firmware, you should check all the connection to the MFP Control Board. In the worst case scenario, you should change the board. I hope a reset will do the job :)
charlibravo
05-09-2008, 12:59 PM
CF023
MsgQue OverFlow
WHERE CAN I FIND NEW FIRMWARE
charlibravo
05-09-2008, 01:16 PM
where to find "MFP Control Board" on my bizhub c252
ni311
05-09-2008, 01:49 PM
You'll find PWB MFP in the back of the machine. It's the big board with all the outside connectors on it.
A new firmware you'll find on any KM site.
charlibravo
05-09-2008, 05:50 PM
Please tell me how to reset PWB-MFP and how to format HDD?
charlibravo
05-10-2008, 10:37 AM
I can´t find C252 MFP controller firmware on any site.
Please help me :-)
laserman06
05-10-2008, 11:56 AM
You can find the the firmware on Konica's website under the service tab.
ni311
05-10-2008, 12:48 PM
You can reset the machine not only the MFP board. To reset the copier, shut it down from the main power off button, keep the Utility/Counter button pressed and power it on. Keep the Utility/Counter down until the Trouble/Reset button shows up on the touch screen. Press it and power off and on the machine.
charlibravo
Please tell me exactly url adress because I can´t find this firmware on any site (i´m so stupid or what :-)
Please forgive me for disturbance :-)
Thanx in advance 8once again9
ni311
05-10-2008, 01:01 PM
what is the firmware version on your machine?
charlibravo
05-10-2008, 01:10 PM
I try shut it down and then press (and hold) Utility/Counter button, but nothing.
Once again please send me exact adress where can i find new firmware, because I canīt find it myself on any site.
Thanx in advance
charlibravo
05-10-2008, 01:13 PM
My printer controller firmware is:
4038-3000-G00-48-000
ni311
05-10-2008, 02:14 PM
give me your email address, the files are too big and I got an error
charlibravo
05-10-2008, 02:19 PM
my e-mail is: rin@rin.hr
ni311
05-10-2008, 02:24 PM
going out now
charlibravo
05-10-2008, 02:34 PM
My service tehnician tell me that I must reset imaging unit to resolve this problem, but didn´t tell me how to do this?
Any manual?
ni311
05-10-2008, 02:56 PM
The code has nothing to do with the imaging units. How many copies the machine did?
charlibravo
05-10-2008, 03:12 PM
about 3500
I understand the code has do nothing with the imaging unit, but i still want to know
how to reset imaging unit?
ni311
05-10-2008, 03:38 PM
you need a device to reset it. anyway, you don't really need it. from copier software, you can tell it to go further even if the life on the IU has ended.
atharpe
09-05-2008, 07:16 PM
I have reseated all connectors on MFP board, updated firmware, and reformatted HDD. Still have errors every few days, any suggestions? :mad:
