I have a Bizhub C35 that gave the message "toner not installed". We have installed 3 cartridges so far and updated firmware to latest! It is the Y cartridge. We did also replace all the IU's as they were all due. We cannot get this message to clear. PRCB board failure? I removed the toner chip and installed and still got the same message so, it is not even recognizing anything in the slot. Any help would be appreciated!
"Toner not installed" message
Re: "Toner not installed" message
I just checked the parts manual it looks like the readers are the same part number for each of the different toner cartridges. Perhaps you could try swapping to one of the other units to see if it records the same message. This will help eliminate if the reader is the problem before you change boards.Comment
