darkdevil400
03-07-2015, 09:11 AM
Hello guys, I'm having troubles with my machine;
For a non explicable reason this machine is almost not dumping toner to the developer, it is all lost and is going to the trash container and, logically i print a test page and i can observe the image without quallity at all, poor of colors. After that i manually dump toner into developer and after that i do a test page; quallity is now much better, image is very colorfull. After that i do gamma correction, and its passes without any trouble (i say this because some times it appear error 1 or 2) then i do a test page and again, i have lost quallity.
After i do again manual toner dumping and i do not do gamma adjustment, copy quallit y is awesome, but after +/- 40 copies quallity instantly fall down.
May it be problem of gamma correction adjustment sensor?
i'm trying to solve it almost a month and a half and i'm getting out of ideas, i'm stuck. I dont know what to do, tryed almost everything i could do to get this machine working, and with, aparently no good results on it.
So one of my last chances to get it working is try to change the firmware, so it would be really nice to have many different firmwares to check if this problem can dissapear.
I'm desperate, really i do.
Please, if someone have any avaliable firmwares for this machine it would help me a lot.
Thank you guys.
Thank you guys.
