View Full Version : Miscellaneous Need to disable automatic size detect on Bypass - Bizhub C284e
nenebrown
03-12-2015, 01:16 PM
Hello, guys. I´m having problems with auto size detection on Bypass. I use some paper with 193mm x 660mm, but the driver don't accept values lower than 210mm. When I put the paper, the printer rejects because paper is 193mm, and in the driver the value is 210mm. Is it possible to disable auto size detect on bypass?
Thanks in advance!
habik
03-12-2015, 02:23 PM
Thanks in advance!
Have you tried custom size on the MFP?
nenebrown
03-12-2015, 02:59 PM
Hi, habik. It´s a mini-banner print. In this case, you cannot put custom size in the machine, I think... is it possible?
emujo
03-12-2015, 03:15 PM
Create a custom size, width can go to a short as 90 mm, length can be as short as 139 mm. Emujo
nenebrown
03-12-2015, 04:02 PM
The driver doesn't accept this values while using Mini banner. It changes to 210mm, instead of 193mm.
Then I put 210 x 600, but in the MFP, when I adjust the tray to 193mm, the machine rejects the paper. And in the mini banner mode, the machine does'nt allow any adjustments in the screen.
2842128422
emujo
03-12-2015, 04:27 PM
When we do banners, we use Power Point as the file type and banner mode on the MFP. We create a custom size for the power point slide and is has always worked. I'm not sure what a mini banner is, but give it a try. Emujo
nenebrown
03-12-2015, 05:01 PM
Mini banner is the special mode in Bizhub, you can print up to 1200mm x 297mm; I use 193 x 660mm, but in this special mode, you only turn on this feature in the machine; it´s not possible to enter any values. And in the driver, the size is 210mm minimum, in this special feature. So, I put 193 x 660, the machine changes to 210 x 660; the paper is 193mm, so when I put in the machine bypass, the machine rejects, because is not 210mm; the sensor of size recognizes 193mm.
emujo
03-12-2015, 05:23 PM
never heard of it (maybe it's a regional thing) but if you can't make any changes to the settings, then it looks like you will have to find the matching paper size to complete your mini banners. Emujo
907tec
03-12-2015, 10:13 PM
I would just put a shim in the bypass tray that holds your 193mm paper snugly and leaves the paper guides at 210mm. Adjust the document margins to make sure you don't print in the "extra" 17mm of paper that isn't there. Worth a shot anyways, and at least you'll figure out whether the rest of the paper path sensors will even accept 193mm paper.
nenebrown
03-12-2015, 10:46 PM
That´s a good idea! I´m gonna try!
Thanks!
