View Full Version : BIZ HUB 951
antone
03-13-2015, 02:54 AM
For some reason copies get light fill.Even after a PM...a short time later copies get light.Density doesn't stay at this print shop!!![emoji20]
blackcat4866
03-13-2015, 03:02 AM
What parts did you replace on your PM? Which PM? What simulations did you do? =^..^=
antone
03-13-2015, 03:04 AM
Replaced drum an developer.. 750k density just doesn't stay!
blackcat4866
03-13-2015, 03:15 AM
You really ought to change the change at least the corona wires, grid, wire cleaners, drum blades, and do the drum peculiarity adjustments. I would not call drum and developer a complete PM by any stretch of the imagination. You might glance at the PM recommendations in the manual. =^..^=
antone
03-13-2015, 03:18 AM
750 pm kit contains all these parts!!!
JR2ALTA
03-13-2015, 03:25 AM
did you do the peculiarity like he said?
also fuser pressure?
does the quality last at least for while? you may have toner add problems
Zackuth
03-13-2015, 02:55 PM
You have to run the peculiarity according to the manual. If you miss a certain step, the copies will be light and you'll have to replace the developer again. I don't remember which step, but I missed it on my first PM for these machines.
blackcat4866
03-14-2015, 04:00 AM
Then perhaps you should install the kit. The way I'm reading your first post, you have "Replaced drum an developer.," Spare me the temper tantrums, please. =^..^=
