View Full Version : konica minolta 7272
cypcopier
03-14-2015, 08:49 AM
Hi ,
1 have a Konica Minolta 7272 and at display 'please wait for a while' and its not working. does anybody help me please .
regards
pepper38_cnd
03-14-2015, 03:44 PM
There are just too many things on that machine that can cause a "Please Wait" message. More info is required.
What have you done so far?
Do the fuser lamps cycle on and off?
Does the finisher initialize?
Do all trays lift into position?
Have you cleared Memory and HDD?
If left long enough does it eventually come up with an error code?
Ok with absolutely no information here is my guess:
1. Dirty sensors on toner control board or bad board.
2. Bad interlock either front door, fuser latch, or ADU latch take your pick or check them all
3. Scanner control board
4. Bad memory
5. Bad HDD
6. And just for good measure everybody's favorite "Firmware".
7. Time to upgrade.
blackcat4866
03-14-2015, 04:57 PM
Did you please wait for a while? =^..^=
copier addict
03-16-2015, 01:29 PM
Have you checked to see if the toner bottle is empty?
rbazan
04-03-2015, 03:46 PM
Description
PLEASE WAIT OPERATING message is continually displayed at power up.
Solution
CAUSE: Failed Scanner Driver Board Assembly.
SOLUTION: Replace the Scanner Driver Board Assembly (p/n 56AA-9091).
