View Full Version : Miscellaneous Creo IC304 Plus BHC6501 FS503 Main Tray problem
icemanhi
03-16-2015, 07:56 AM
Hello,
I have a problem with the print on the main tray when i select the main tray is printed on the subtray. I have only 1.0 software version.
Config
C6501 + FS503 + IC304 Plus
I ask for any help
methogod
03-16-2015, 11:09 AM
think you need a Relay in there... RU503/504 for that to work like that...
Methogod is right you need an RU between.
icemanhi
03-19-2015, 07:40 AM
Thanks for all.
But. I not exactly the problem described, this configuration work correctly without RU.
But we had a problem with the CREO (BSOD) and had to restore the image of the software.
And from that moment the problem is. I think the problem may be with the software version.
We do not have update for it and restored it to the oldest version 1.0.
Albonline
03-20-2015, 06:00 PM
Thanks for all.
you need the ru to use creo, you could get away with this if you had a fiery .
