Capodastra
03-18-2015, 02:14 PM
Hi, I am printing both sides of an A3+ sheet. The first side is perfect, but when I turn the sheet over and print the other side I am getting a double image or "slurring" of the original image and I cannot see what the issue is in the printer. The black drum is clean.
I have put 4 sheets in the bypass tray - two were blank and the other two had one side printed already. The first two are perfect, but the image that has been printed on side has this blurring effect on it.
I print the first side as thick 1 (120gsm Pro-design) and when i print the other side I use the Thick 4 setting. I have tried different permutations and still the double image happens.
Desperately need to get to the bottom of this issue if anyone can help.
I have attached a jpeg of the second side (which I hope will upload ok)
Many thanks
Cappy
Many thanks
Cappy
