View Full Version : EP2120 Imaging unit fuse
ebm
05-13-2008, 09:59 PM
Does any one know the value of the fuse to reset the Imaging Unit counter on the EP2120 model?
Thanks.
Rudi
05-14-2008, 02:21 PM
Why do you want to replace the fuse , if all you have to do is take out the toner bottle and short out pins 4&6 on pj3 on pwb a remember the mach must be off when you make the connection then switch it on while creating the short as soon as the mach starts to run or within about 5 sec break the short again.
nmfaxman
05-14-2008, 03:34 PM
Precision Roller PN m9970. $5.50
ebm
05-14-2008, 06:27 PM
I wanted to know if the EP2120 Imaging Unit fuse is the same as the fuse in the bizhub C450 fixing unit. Katun sells them $17.35/bag of 20. Thanks.
Mark B
05-15-2008, 01:33 PM
It is a Picko fuse I do not think there is a value.
cobiray
05-15-2008, 06:06 PM
The Katun p/n was 35010515. We had ordered a ton back in the day for some reason. Not sure of the new p/n if it might have changed with the merger.
Accentcp
05-28-2008, 08:50 PM
1/16 Amp pico fuse
ebm
05-29-2008, 12:55 AM
FYI, the fuse Katun sells for rebuilding the EP2120 Imaging unit is the same as the fuse to reset the count on the Bizhub C450. Thanks.
