View Full Version : Konica 1216 service call reset
hekotez
05-14-2008, 12:27 PM
As the title says, we have here a Konica Minolta 1216 that my college serviced, machine is ready to go but the servicing request light is on and he doesnt remember whats the steps in service mode to reset it.
Can anyone please help out on this?
Thanks alot for any help in advanced.
vj200729
05-14-2008, 04:02 PM
press 25 switch on .enter 47 .press start.enter 1 .press start.switch of and on.
dogsbody
05-15-2008, 09:24 AM
if i remember rightly,
47 mode, 51, start for L-detect (after dev change).
47 mode, 90, start for the PM counter.
hekotez
05-15-2008, 12:17 PM
thanks for the input doma873
doma873
05-15-2008, 01:18 PM
Is this ment to be funny or just a joke. The above quote is to reset F34 , 35, 36 codes that relate to fuser error. Nothing to do with reseting PM counter.
Now for an old trick. If you haven't replace the dev and still want to reset the pm count go into 25 mode and set p33 p34 p35 to all 0. Then turn machine off then back on. If you do 47mode 90 you will have to perform L detect ofter that 47mode 51 otherwise you get error f26 from memory.
Be a long thme since i have worked on these models but i remember servicing thousands of them years ago
fareeduddin ahmed
11-17-2008, 01:28 PM
1 ) hold 4 and 7 key together and switch on machine then enter key 9 and 0 then press print this will rest your service call indication
switch off machine
2) hold 2 and 5 key together and switch on machine then enter key
5 and 1 then press print this will callibrate developer one to two
munties machine stops when over switch it off and on will solve
your problem
3) ** its all this not adviceable without changing of pm kit which is due
be standard to fallow as recomonded by manufacturer
konikilla
11-21-2008, 08:23 PM
In service mode
set P27 to 90
and then
set P28 to 09
This doesn't reset the PM counter but changes the PM counter to it's maximum setting. This way you'll get the service light off without running the risk of having to change the Developer.
minolta35
10-17-2009, 10:56 AM
I've got a 1216 display P25 and P26.I don't know its mean and how it fix or reset it?
JustManuals
10-17-2009, 11:11 AM
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
from The Internet's largest collection of manuals (http://www.justmanuals.com)
Paul@justmanuals.com
Mikey
10-17-2009, 08:03 PM
That means you have problem with toner density. Check the TDS. To reset go to 47-51.
Naveed Shahid
10-20-2009, 05:51 AM
hello
try to 47-51
