View Full Version : OEM toner for bizhub pro 950 on bizhub 600 / 750
smart-refill
04-11-2015, 03:30 PM
hello
did you try to use OEM toner for bizhub pro 950 on bizhub 600 / 750?
thank you!
tulintron
04-22-2015, 08:09 PM
hello
thank you!
Functions normally. I have done tests on equipment and after process adjustments, showed a positive result.
smart-refill
07-05-2015, 05:43 AM
could you tell me, what adjustements I have to make on biz 600?
now the equipment work with a noname toner (I think is not katun)
thank you!
allan
07-05-2015, 09:58 AM
All the Konica b/w machines uses the same developer type. I use DV511 instead of DV710 on the B600 type machines, it seems like the machine is ok running on a little less developer. It lasts just as long as the DV710 and it puts less stress on the devtank. You can get up to 200K on a bag.
So some guys will use TN710 to fill up B1250 bottles. The generic toner i use works very well and you can save a lot of money with the right stuff, or u can use KATUN if you hate yourself.
The toner mix could be different because of the engine speed it needs to melt and set faster for quicker machines.
smart-refill
07-05-2015, 04:52 PM
allan, thanks for your answer.
but, when you use another toner, not OEM, other "compatible" / generic brand do you have to modify any settings in service mode?
thanks again!
allan
07-05-2015, 05:50 PM
thanks again!
No, it works like the original.
smart-refill
07-05-2015, 07:57 PM
katun is not a good brand for this machines?
what kind of generic toner do you use? could you send me a link, or a distributor?
thank you!
allan
07-05-2015, 08:19 PM
Its brandless and comes from Europe. I think its manufactured by a company called GHS.
We get it from a supplier that imports the stuff. There drums and parts are good aswell.
smart-refill
07-05-2015, 08:31 PM
thank you!
I cannot find this brand here.
I'm afraid I have to improvise. I must choose between katun and OEM.
I will try to use OEM toner for bizhub 950.
methogod
07-06-2015, 09:16 AM
Running 920/950 and now 1051 and 1200/1250 for years, i would not use toner down but up may be ok...
I know for sure that 920/950 toner is the same and works just fine in fact we modified the toner hopper to use either toner on any type of 920/950....
we did the same for the 1051/1200/1250... having a mixed bag of the machines...
I would not skimp on Developer... its not worth replacing all consumables over $50-$100...
I have also found that these machines run much better with high volume - for a small business environment i would stay away from production machines...
go with the smaller slower 651 and 751 or a color machine...
less head aches...
