View Full Version : Bizhub C451 - copies wrinkled & Ilde noise - squeaking and knocking noise
thendral
04-13-2015, 12:49 AM
Hello All,
Bizhub C451 - Copies wrinkled. (See attached Pics).
I tried this from the thread:
http://www.copytechnet.com/forums/konica-minolta/72333-bizhub-c351-wrinkling-paper.html
Images:
http://s29.postimg.org/fqxx8adk7/20150412_183641_resized.jpg
http://s28.postimg.org/uwhyywjzh/20150412_183724_resized.jpg
Also when Idle I hear weird noice.. doesn't appear like the famous fuser noise.
It is weird squeaking and knocking nise..
I tried this thread solution too no help:
http://www.copytechnet.com/forums/konica-minolta/40225-bizhub-c451-noise.html
Here is the video:
http://tinypic.com/r/so8kko/8
Any help on both the issues is much appreciated.
allan
04-13-2015, 02:57 AM
The idle noise it "normal". Is the image not distorted?
Maybe a flat spot or something going slow fast slow fast?
Is the paper OK?
Looks like it is cause by a roller the covers the entire page, that leaves the registration and fuser.
wseyller
04-13-2015, 03:38 AM
Ive seen this before but my memory of it is not good. I believe it is a common issue with this model. It is around the fuser section but maybe not the fuser itself but the "eject drive assy" rings a bell.
Correct me if I'm wrong.
hotfuser
04-13-2015, 09:18 AM
You are correct Wseyller it is the eject drive system that causes wrinkled paper usually trailling 1/3 od A3 paper.
the noise if it is not the fuser is the duplex turnaround section. They did modify it with black rollers as the un-modified had white plastic ones.
if you remove the idle gear and run the copier it will give you an idea.
allan
04-13-2015, 10:13 AM
Thanks for that tip. I know about the duplex roller noise. But the fuser idle actuator(to check if fuser is running) also makes a high pitched noise. There is no winning the noise on those models. do you have the modification bulletin for those duplex parts?
thendral
04-13-2015, 01:02 PM
Thanks a lot to all of you. You guys are great.
Here is the action plan:
Wrinkled Paper:
Image is clear. Copies are also clear.
I will check out the eject drive assembly.
Noise:
I will check the fuser again.
I will remove the idle gear and run the copier to see if that reduces the noise.
I will also check the duplex turnaround section.
Desert Rat
04-13-2015, 02:25 PM
Seems to me I just fixed one like that. It was the BHC552. It was a squeek coming from a couple of
Gears. After that it was a ticking sound of a gear skipping a tooth especially when paper was fed.
It turns out that the gears on the spring loaded drive for the duplex entrance were the source of the squeek.
The gear that drives those two gears would skip a tooth. This slows the front part of the page,
The trail edge I still at normal speed and pushes the page and causes the wavy trail edge.
It was the bushing for the shaft that drives the lower gear of this three gear assembly.
I could touch the lower gear and the shaft & gear would move around.
Looking at the right side of the machine with the door open it is located in the upper right area.
I think I had to pull the fuser motor and fan and some other stuff to get to the bushing.
HTH
neil greenhough
04-13-2015, 07:31 PM
Yes the good old 451, the machine that came with a free set of ear defenders for the unlucky customer who had to sit next to it all day, every day! Just joking, they weren't too bad. Yes your right the bushing ovals out causing the gear to skip, hence the uneven drive speed. The one way gear on the exit unit can cause a similar issue and show as a finisher jam. However in this case stick to plan A. We had a customer who was very picky and call you out for the tiniest of squeaks. We have a bit of a joker who works for us and he decided to teach her a lesson. He bought a realistic looking toy rat and smuggled it into the machine and then called her over saying he had found the reason for the squeak. When she came over he pulled the rat from inside the machine and she screamed. That surprisingly stopped her being so fussy!!! Shame it wasn't a banging noise because he would probably taken his gun in!!
Synaux
04-16-2015, 12:22 AM
Eject Drive Unit A00J R726 11
I think I have a used one that was changed for diagnostic purposes (it turns out if was working just fine) that I can sell to you for cheap if this is one of budget machines that no one wants to spend money on.
thendral
04-22-2015, 10:56 PM
Hello Thanks to all of you gave ideas where to look.
Here is the problem:
It is in the fuser there seems to be one gear lost several teeths. See pictures below:
http://s23.postimg.org/w6z2nr9bb/20150422_165405_resized.jpg (http://postimg.org/image/w6z2nr9bb/)
http://s23.postimg.org/m4kal0uef/20150422_171321_resized.jpg (http://postimg.org/image/m4kal0uef/)
http://s23.postimg.org/3rjpagjxj/20150422_171332_resized.jpg (http://postimg.org/image/3rjpagjxj/)
http://s23.postimg.org/vdmgv53af/20150422_171345_resized.jpg (http://postimg.org/image/vdmgv53af/)
http://s23.postimg.org/xxi3p8quf/20150422_172305_resized.jpg (http://postimg.org/image/xxi3p8quf/)
http://s23.postimg.org/gzj33ehgn/20150422_172409_resized.jpg (http://postimg.org/image/gzj33ehgn/)
Picture #4 & #5 (click to enlarge all the pics) see the area I circled with red.
My question now: Is it possible to buy this gear? I don't see it anywhere even in the parts manual..
If I can please let me know. Or if any one has old used fuser and can ship it to me I am willing to pay.
I hate to see this fuser go waste as it only has 20% usage.
Thendral
ZOOTECH
04-22-2015, 11:13 PM
If you find a gear and want to replace it, you may want to find out what caused the teeth to get sheared off that way first.
thendral
04-23-2015, 03:15 AM
Thanks ZOOTECH. It was because of the transportation. The copier was transported from one place to another.
I did checked other gears those looks good.
Thendral
wseyller
04-23-2015, 03:32 AM
Konica Minolta does list gears on this model as separate items only the complete fuser. Only other option is if you can find aftermarket or find a used fuser
thendral
04-23-2015, 04:53 PM
wseyller,
You mean konica minolta "DOES NOT" list gears separately correct?
I couldn't see it listed in the parts manual either..
Is there any place I can buy after market gear?
wseyller
04-24-2015, 12:24 AM
wseyller,
Siva
Yes I meant does not.
