View Full Version : oce 3165 w/m6106 code
can i just replace the main motor on this one or do i have to reset it after doing so. thanks t
you have to reset the error in servicemode "31"
are you sure it is the mainmotor?
have u ckd t ntc in t ttf unit????
also heater lamps
mecanico
11-21-2008, 03:22 PM
If the problem was at the main motor, then you must rearm the clixon (thermal fuse) in the TTF.
