View Full Version : Bizhub 600 Always warming Up
Wasfil
05-15-2008, 04:35 AM
Bz600, after I do Copy and hushed 1minute or more, lather than The machine canot use, at screen come up this Message "Please wait Warming up the machine" Before that always eror code C2803 & 2804, My counter is 300.000
fixthecopier
05-15-2008, 05:21 AM
On other models of Konica Minolta, when he machine keeps warming up, it is looking for toner to complete the job. If the bottle has toner, and conditions are humid, you may have to clean out the hopper under the bottle holder.The toner could stick together around the auger, not allowing it to feed into the DV box.
Wasfil
05-15-2008, 05:47 AM
Thanks, but that to long time and canot be use until I tur OF and Turn On again. And That problem always happened every day. :)
just follow fixthecopier said, check the thing .
Downunder
05-15-2008, 11:47 AM
At 300,000 hope you have replaced drum, starter, blade etc. Best to do this at correct time, 250,000, or problems will come your way.
RockETop
05-16-2008, 03:24 AM
I have a machine with over 1M copies that just started this today. I'll let you know what happens. RET
Edit: after a little research, I vote TCSB. I had already cleaned out the process unit. I'll hose out the toner supply unit tomorrow first....cheaper!
doma873
05-16-2008, 07:47 AM
I would do the above first. I have also had a faulty Dmax sensor cause this problem also. Make sure the sensor is very clean. If you check the service code counter you may see a few dmax errors listed..
RockETop
05-17-2008, 10:39 PM
TCSB! Went right to work.
Run drum peculiarity. you may get errors.
Wasfil
05-19-2008, 08:52 AM
PC Drum, Starter tobe replace before, but the problem has be come after amoment (1minute) I do copy once in the screen "Warming Up Ready to Scan" I can do Scan, but the result print not going out.
I have do : Drum Peculiarity - Auto MAx. Density Adj the result is Ok, then Auto gamma Adjst. (1dot) and (2dot) the result is Error 1, in the book that mean TCSB dirt,
In other machine i have change/replace with New TCSB the problem is lose. (Ihave 2 machine with same problem)
Thanks alot for All guys.....:o
redhotrob
05-19-2008, 11:46 AM
It may sound kind of strange, but I had one of these machines that would go to warm up and not come out unless the power was reset. I checked everything and all seemed ok. With nothing left to do, I flashed the machine. It already had the latest firmware, but I did this anyway. It's been months now, and the problem has not came back.
pepper38_cnd
05-19-2008, 12:50 PM
Could be a bad front door interlock switch, they can cause weird problems.
d7guitar
05-20-2008, 11:07 AM
Contact tech support. They know of this problem and have step by step things to check. Everyone else here has offered great advice and is sending you on the right path for what to check. Ultimately if all other fixes don't work you may have to follow the TAD under solutions for this model that walks you through resetting the machines firmware to the base level and then steps you through each phase of firmware revisions to bring it current. We had one doing this exact thing you described that required a complete firmware rewrite and has been fine since. Check "Solutions" for the TAD on mykonicaminolta.com
Juggy
05-25-2008, 03:01 PM
you will get this message warming up once you find that the Drum unit is heavily contaminated and the dmax sensor is not reading the correct value .You need to clean the drum unit throughly and then check the drum area above the Dmax sensor if it is wornout compared to rest of the area, then replace the drum. Next check that your bias to the DV tank is in proper contact with the DV roller and correct the problem This will avoid frequent contamination of the Drum unit and your Problem will be set.
Christan
05-26-2008, 04:42 PM
you should try to replace the imaging processing card it should be defaulty. Check with you department there is a modification kit (from Japan) for the fault.
Wasfil
05-27-2008, 05:25 AM
I change TCSB (Toner Control Sensor Board) in Developing unit, and my trouble finish. Thanks all guys:)
Steve0
05-27-2008, 02:57 PM
Hi Wasfil,
Thank you for your feed back post.
Accentcp
05-28-2008, 10:29 PM
Can also happen if the counters are not cleared on PM.Messes up aging..
douglasdouglasv
12-12-2012, 11:05 PM
I have multiple BZ 600's in the field. Please wait is always a dirty, or faulty toner control sensor board.
MAD0RAM
12-12-2012, 11:53 PM
X2
EarthKmTech
12-13-2012, 08:43 PM
every single time i've had this issue its been dirty / failed drum sensors.
A clean machine is a happy machine (A tall order on these things if they're using shit paper)
arsalan ali
11-07-2013, 10:48 AM
PC Drum, Starter tobe replace before, but the problem has be come after amoment (1minute) I do copy once in the screen "Warming Up Ready to Scan" I can do Scan, but the result print not going out.I have do : Drum Peculiarity - Auto MAx. Density Adj the result is Ok, then Auto gamma Adjst. (1dot) and (2dot) the result is Error 1, in the book that mean TCSB dirt,In other machine i have change/replace with New TCSB the problem is lose. (Ihave 2 machine with same problem)Thanks alot for All guys.....:othe same thing happened with me in bizhub 600 after intalling new drum . machines goes on warming up for long time time :(
chand226
02-01-2014, 08:32 PM
i read all the threads
i have 200% correct formula for this copier (biz600/750/ di7210/7272)
contact me at chand226@gmail.com
chand226
02-01-2014, 08:36 PM
no need of to change any firmware and drum.
i have 200% correct formula for this copier (biz600/750/ di7210/7272). no toner on corona, no warming up, pleasewait.
CompyTech
02-01-2014, 11:26 PM
Then why don't you post it here? It's not like its some big trade secret any more. Those boxes are old as the hills, most people just want to fix the damned things and move on to the next call.
Sent from my Nexus 7 using Tapatalk
chand226
02-02-2014, 06:08 AM
contact me.. i can solve this problem on best way
Synaux
02-03-2014, 06:05 PM
contact me.. i can solve this problem on best way If you are unable to post anything meaningful here, it is doubtful that you can assist anyone who may contact you. GTFO, Thanks!
solidzdawg
02-03-2014, 07:17 PM
1.) Clean the sensors extremely well in the drum carriage.
2.) Ensure that the developer is not extremely worn.
3.)take front fusing unit plastic cover off, cheat front doors, and ensure lamps are running
chand226
02-04-2014, 06:00 AM
its a big secret
fredr
01-07-2023, 07:19 AM
Add developer powder to the dev
