View Full Version : Fax forwarding file types bizhub 363
Cookr
04-23-2015, 02:20 PM
Have a customer with a bizhub 363 and they want the faxes forwarded to there PC which I have set up but they want it to be a .tiff not a .pdf and i stoped in quickly to check it out but could figure out if there is a way to do that. I already have there scans set to default to a .tiff but i dont see a way to forward faxes as .tiff. Any Ideas? Thanks
emujo
04-23-2015, 04:05 PM
To set the MFP to default to TIFF when forwarding a fax, perform the following:
1. Enter Service Mode.
2. Select System 2.
3. Select Software Switch Setting and set software switch 28 to a hex value of 08.
4. Select Fix.
5. Select End.
6. Select Exit and reboot the MFP.
We see this need when the faxes are routed to a watch folder that grabs the documents for processing but only looks for .tiff formats. Emujo
allan
04-23-2015, 04:22 PM
emujo, where did you find a list of soft switches for this machine? i can seem to find them in the fs manual.
Cookr
04-23-2015, 04:30 PM
Sweet. Thanks emujo.
emujo
04-23-2015, 04:44 PM
SM doesn't list all of them...some sort of secret info KM doesn't put out to GP. Most of the special switch settings can be found by doing a keyword search on the KM website. Emujo
allan
04-23-2015, 04:57 PM
Difficult to find then. I am working for a Dealership under Konica Minolta South-Africa and have access to there knowledge base. Just did the search there and got that info of of a C360 TAD. Seems like the guys in JHB in doing a good job with the new knowledge base.
