View Full Version : Bizhub fax issue
christian09
04-24-2015, 06:30 PM
Interesting problem...bizhub223...everything great except fax Rx's only receive 1page of multiple page faxes,from multiple numbers, and tested ricogfax just fine.
copydocinc
04-24-2015, 06:37 PM
Unplug power cord, after turning machine off. Plug back in, try again. I know this is elementary, but the best of us have forgotten to do the basics form time to time
christian09
04-25-2015, 03:03 PM
Thanks doc. Already tried it.
allan
04-25-2015, 04:01 PM
Do you think its a bad line?
Or that fax configuration is wrong.
copier tech
04-25-2015, 04:22 PM
I agree this is most likely a bad line, plug in a handset & make a call, listen for crackles etc
christian09
04-28-2015, 07:46 PM
Thank you for helping. Dumb question, but how do we test for a bad line?
I have a hard time overcoming a customer that says "why is it working on my Ricoh fax?"
allan
04-28-2015, 07:57 PM
You can connect a handset and listen for crackling sounds and any abnormality.
Is the machine connected to PSTN or PABX?
allan
04-28-2015, 08:04 PM
Sorry missed you post there:o
Ok go to the job log and get the code that pops up there under detail. that could help, does the machine give a failure message or a NG delivery report.
Did you check the marketing area?
Did you reinitialize the fax?
What have you tried so far?
christian09
04-29-2015, 05:04 PM
Hi there.
Checked the line....clear
Set for pb.
Tried: ecm off,slowed to9600,reinitialize fax,next step is new fax board.
It s quite odd, sometimes it prints 1 page of a multipage, other times nothing. Yesterday I sent 3 pages OK, then nothing...no real pattern. When you mention marketing area, I recall like a353 set to Japanese. And it caused odd fax issues. Will check this.
Thanks again.
Iowatech
04-30-2015, 02:10 AM
For what it is worth, it appears that there are a lot of people with Bizhub experience here:
http://www.copytechnet.com/forums/konica-minolta/
You might try posting there too.
RRodgers
04-30-2015, 06:29 AM
As mentioned, take it out of JP mode
(happens all the time)
