Does anyone have a source for obtaining flash cards for firmware updates for the older color MFP? I have not been able to find any that work. I dont know if its a formatting issue with some of these cards.
Firmware update card for older color MFP
Re: Firmware update card for older color MFP
I feel your pain *sigh*
http://www.copytechnet.com/forums/konica-minolta/96502-cf-card-bh-c-353-a.html
Found out after a plethora of different useless CF-Cards worth in total over USD 160.00, that the only working one is an old SanDisk Shoot&Store 128MB card which I got from eBay.
Before putting the firmware (xxxxx_cf.tar.gz) I formatted it with the format option within the Firmware Imaging Toolkit. Worked for my BH-C-253's and also BH-C-353 machines.
(until now........)
HansLast edited by Hansoon; 05-10-2015, 05:54 AM.“ Sent from my Intel 80286 using MS-DOS 2.0“
https://www.copytechnet.com/images/smilies/biggrin.png -
If KonicaMinolta is obviously not willing and/or capable to optimize a simple update procedure by using standard generally available smart cards, which are directly communicating with the machine, than I cannot imagine that a rather complicated and tricky procedure like the ISW firmware updating via a network connection will work. I never ever even thought about using it after studying the procedure in the tech manual.
Too many things can and WILL go wrong wit that. When you figured out which stupid ancient outdated operating system on your computer you would need than there will be a load of other hurdles to overcome and when you finally succeeded to do that all, you would likely have to cancel the procedure because some stupid information will confront you such as: "You Can Use This Procedure Only When Your Grandmother Has Her Birthday" All of course under the condition that it will work only on leap days and when there is a Full Moon at the same time.
Most likely the network connection to the machine will get f'd up during the procedure leaving you with a boat anchor at best.
Rant Over.
Hans“ Sent from my Intel 80286 using MS-DOS 2.0“
https://www.copytechnet.com/images/smilies/biggrin.pngComment
Id always use that method if I could but new models firmware broke that feature
It's still easier than finding a cf card imo
Most of the guys that don't like it aren't very IT savy
Our IT Guy made a special ftpserver dedicated to I'm which made things much easier I guess. If you used IWS or filezilla it might be more complexComment
I don't deal with those crappy cf cards anymore unless it is a bizhub 200/250/350/222/282/362 which doesn't need firmware imaging toolkit, just drop the files on the card and works with most cf cards.
ISW with ftp using ftp utility is pretty simple once you get the hang of it. With some models you have to use the included make tar bat file to create a single tar file.
Also great if you have to upgrade several MFPs at the same time.Comment
