ADF Original Detection Bizhub C364e
  • JKinSC
    • May 2025
    [Misc] ADF Original Detection Bizhub C364e
    Is there a way to permanently set the page orientation to Auto detection? When a document is set in the ADF in portrait orientation and the user does not manually select portrait from the touchscreen, the output prints out in landscape orientation, wasting paper.
    • 14401
    Re: ADF Original Detection Bizhub C364e
    Make sure it is set to "Auto paper" for the paper trays.
    • wseyller
      • Sep 2012
      • 1129
      Also there is an automatic document rotation setting in admin>copier settings. I know its in there somewhere but the auto paper is part of it too.
      Edit: Decided to look it up.
      To display: >>View
      • [Utility]
        • [Administrator Settings]
          • [Copier Settings]
            • [Automatic Image Rotation]
      Select the setting in which the image is to be automatically rotated if the original orientation is different from the paper orientation. [When Auto Paper/Auto Zoom is set] is specified by default.
      [When Auto Paper/Auto Zoom/Reduce is set] The original image is automatically rotated when [Paper] is set to [Auto], and [Zoom] to [Auto] or Reduce.
      [When Auto Paper/Auto Zoom is set] The original image is automatically rotated when [Paper] is set to [Auto], and [Zoom] to [Auto].
      [When Auto Zoom/Reduce is set] The original image is automatically rotated when [Zoom] is set to [Auto] or Reduce.
      [When Auto Zoom is set] The original image is automatically rotated when [Zoom] is set to [Auto].
      • JKinSC
        I found what I needed:
        From the main touchscreen:
        • [Application]
          • [Basic]
            • Paper ~ select "Auto"
        Now when paper is inserted into the ADF in portrait layout, the output is also in portrait without having to select it from the screen menu.
        Thanks for your input!
        To display: >>View
        • [Utility]
            • [Copier Settings]
